HOW TO
Emulation/Output format: CALCOMP 9x00 - ASCII Fmt 3
Interface:
Baud: 9600
Data: 8
Parity: none
Stop: 1
Modes: Point
Increment: 0 = OFF
Stream Rate: MAX
Resolution:
Lines Per Inch: 1000
ASCII Options: CR
LF
Transmit out of Prox: Disable
'ACCUGRID'
'(A2,2F5.3)'
F
F
73.0, 1.0, 0.0
85.0, 1.0, 0.0
12
'0D' 0, '1D' 1, '2D' 2, '3D' 3, '4D' 4, '5D' 5, '6D' 6, '7D' 7,
'8D' 8, '9D' 9, 'AD' 10, 'BD' 12
-1
-1
-1
-1
CON-DIG ACCUGRID x 9600 NONE 8 1
| | | | | |_ stop bits
| | | | |___ data bits
| | | |________ parity
| | |_____________ baud rate
| |_______________ port #
|________________________ format file
This digitizer is only supported in POINT MODE.
If the digitizer passes DIGTEST, but upon subsequent ARCEDIT sessions the digitizer does not appear to be communication with the PC, you may need to remove the REM statements on lines 18 and 19 of the C:\ARCEXE\CMD\ARC.BAT file.
Article ID:000001637
Get help from ArcGIS experts
Download the Esri Support App
