HOW TO
Configure a Summagrid V digitizer
Procedure
Summary
Steps to configure a Summagrid V digitizer.
Procedure
The following is for point mode only. Stream mode is not supported for the this digitizer.
1. Do not load the Calcomp drivers. If you have loaded any their DOS drivers, you need to remove them from the AUTOEXEC.BAT and/or CONFIG.SYS files. Those drivers usually begin with "C:\CALDB\.......". If you loaded the Calcomp drivers in Windows, you need to uninstall them.
2. Configure the dip switches and banks:
a) Load the CD "Tablet Works"
b) Navigate to the directory Sgdosutl\utility\Sg5c) Run Sg5setup.exe
d) Make the necessary setting changes at the DOS window that appears
e) Check the COM port to which the digitizer is connected
BANK    1     2     3     4     5     6     7     8
A X X X
B X X
C X X
f) Set the following parameters on your digitizer:
Baud Rate      [9600]
Parity [None]
Data Bits [8] Stop Bits [1]
[X] Click enabled
Mode [Point] [ ] Always
transmit
Resolution [1000 lpi]
[ ] CR/CR LP
Emulation [CALCOMP]
Format [CALCOMP 9100 1]
g) Select the SAVE SETTINGS button. The digitizer will beep twice to confirm the changes.
h) Select the READ SWITCHES button to confirm the settings
3. Make a new digform for PC ARC/INFO or DAK to communicate with the digitizer:
a) Open a DOS editor, such as Notepad or WordPad
b) Open the digform CAL9100 in the directory C:\ARCEXE\DIGFORM
c) Save the file as CAL9100E. Make sure the file type is set to 'Text Document-MSDOS Format' in WordPad or 'All Files' in Notepad. The files should not have a txt extension.
Make sure the digform looks like this:
'CAL9100E'        CALCOMP SUMMAGRID V digitizer
1 Digitizer device #
'(A3,2F5.3)' Digitizer format
F No menu bar
F Single button mode off
73.0, 1.0, 0.0 X max, x scale, x offset
85.0, 1.0, 0.0 Y max, y scale, y offset
12
'AP3' 0, 'AP0' 1, 'AP1' 2, 'AP2' 3, 'AP4' 4, 'AP5' 5, 'AP6' 6,
'AP8' 7, 'AP9' 8, 'APA' 9, 'APC' 10, 'APE' 12
-1
-1 No shutdown characters
-1
-1
-1
4. Run the CON-DIG command or run ARCSHELLW File > Configure > Digitizer.
5. Run the DIGTEST command or run ARCSHELLW File | Configure | Digitizer Test.
The following is for configuring the digitizer for use with a 16 button
puck:
1. Modify the Format file cal9100 as follows:
'SUMMAV'                    SUMMAGRID V Digitizer
'(A2,2F5,3)' Digitizer format
F No menu bar
96.0, 1.0, 0.0 X max, X scale, X offset
72.0, 1.0, 0.0 Y max, Y scale, Y offset
16
'1D' 2, '2D' 3, '3D' 0, '4D' 4, '5D' 5, '6D' 6, 'ED' 12, 'CD' 10, '7D' 0, '8D'
7, '9D' 8, 'AD' 9, '0D' 1, '#D' 12, 'UU' 0, 'DD' 0
27 37 86 56 13
27 37 82 13 Stream mode on
27 37 80 13 Stream mode off
8 Stream off wait time (Changed from 10)
2. Save this file as 'SUMMAV'
3. Run CON-DIG at the Arc prompt like this:
CON-DIG SUMMAV x 9600 NONE 8 1
| | | | | |_ stop bits
| | | | |___ data bits
| | | |________ parity
| | |_____________ baud rate
| |_______________ port #
|______________________ format file
4. Run DIGTEST to make sure the digitizer is communicating correctly.
If the DIGTEST fails, run a communications test, such as Kermit or Hyperterminal.
Article ID:000001757
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
