HOW TO
Conditionally hide and embed additional questions into a multiple-choice question in ArcGIS Survey123 Connect
Last Published: April 23, 2024
Summary
In ArcGIS Survey123 Connect, formulas can be applied to survey questions to set conditional formatting to hide or embed questions when a particular choice is made. For example, customizing a survey question to show a textbox and a multiple-choice question prompt when the respondent selects 'Yes' to the question.
This article provides the steps to conditionally hide and embed additional questions into a multiple-choice question in ArcGIS Survey123 Connect.
Procedure
  1. Open the ArcGIS Survey123 Connect XLSForm.
  2. Create a multiple-choice question in the survey worksheet. In this example, the select_one yes_no question type is created.
    1. Under the type column, select text to embed a text question.
    2. Specify a name for the question that is not listed in the Reserved worksheet, and under the label column, type <font color=""></font> to display a blank label for the text question. In this example, the question is named 'elaboration'.
The edited XLSForm
  1. Under the relevant column, specify the following formula:
${<targetQuestionName>}='<targetChoiceSelected>'
The relevant column hides the questions and clears the questions' record when the answer chosen is not relevant to the expression. In contrast, the body::esri:visible column hides the questions from view but still records the data.
The code block below is an example of the full working formula.
${firstQues}='yes'
The edited XLSForm
  1. Under the type column, select select_one rating to embed a multiple-choice question with a select only one answer setting.
  2. Specify a name and label for the 'select_one rating' question.
  3. Under the relevant column, specify the following formula:
${firstQues}='yes'
The edited XLSForm
  1. Click Save The Save icon .
The image below shows the additional questions embedded to a multiple-choice question when 'Yes' is selected.
The ArcGIS Survey123 Connect survey
Article ID: 000031366
Software:
  • ArcGIS Survey123 Connect
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
