HOW TO
Conditionally determine if a feature class is located within a specified distance from another feature class using Arcade in ArcGIS Pro
Last Published: October 7, 2024
Summary
When there are many different feature classes grouped closely among each other in ArcGIS Pro, it is difficult to determine if these feature classes are located within a specific distance.
This article describes the workflow to conditionally determine if a feature class is located within a specified distance from another feature class using Arcade in ArcGIS Pro.
Procedure
In this example, a point feature class and a line feature class are used.
  1. Open the Calculate Field tool on the attribute table. Refer to ArcGIS Pro: Access the Field Calculator for more information.
  2. For Input Table, ensure the desired point layer is selected in the drop-down list.
  3. Specify a name for Field Name.
  4. For Expression Type, select Arcade in the drop-down list.
  5. Specify the following Arcade expression in the Expression section. Replace '<lineName>' with the name of the line feature class.
    1. Load the line feature class.
var lines = FeaturesetByName($datastore, "<lineName>")
    1. Return the results if the points are located within the specified distance from the line feature.
return IIF(Count(Intersects(Buffer($feature, <numericValue>, "<unit>"), lines)) > 0 , "Yes", "No")
The code below shows the example of the full working script.
var lines = FeaturesetByName($datastore, "Line1")
return IIF(Count(Intersects(Buffer($feature, 10, "kilometers"), lines)) > 0 , "Yes", "No")
  1. Click OK.
The image below shows the example of the full working script in the Calculate Field dialog box.
The example of the full working script
The image below shows the result of 'Yes' or 'No' if the points are within a specified distance of a line.
The results return a 'Yes' if the points are within the specified distance of the lines and 'No' if it is not
Article ID: 000030048
Software:
  • ArcGIS Pro 3 1
  • ArcGIS Pro 3 0
  • ArcGIS Pro 2 8 x
  • ArcGIS Pro 2 7 x
  • ArcGIS Pro 2 x
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
