HOW TO
Compile and build WxWidgets 2.8.7 to run ArcGIS Engine samples on Linux
Summary
Instructions provided describe how to compile and build WxWidgets 2.8.7.
Procedure
These instructions must be performed on a 32-bit Linux machine that meets the system requirements for ArcGIS Engine. The resulting binaries will be usable on both 32- and 64-bit machines.
  1. Find WX 2.8.7 at the Source Forge site.
  2. Download WxWidgets to a local directory using wxWidgets-2.8.7.tar.gz (or .bz2).
  3. Unpack the source code:
    Code:
    tar -zxvf /<path to sourcecode>/wxWidgets-2.8.7.tar.gz
  4. Change directory (cd) to the unpacked wxWidgets-2.8.7 source code.
  5. Configure the source code with the following command:
    Code:
    ./configure --prefix=<installation location> --enable-unicode --with-gtk
  6. Build wxWidgets using the command:
    Code:
    make all
  7. Install wxWidgets using the command:
    Code:
    make install
    Make sure that <installation location>/bin is in the PATH so that wx-config may be executed from the project's makefiles.
Article ID:000011482
Software:
  • ArcGIS Engine
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
