HOW TO
Compare a field with a substring in another field
Summary
Instructions provided describe how to use Select by Attributes to find all the features for which Field1 is contained in Field2.
Procedure
For example, select features for which Field1='Forest' and Field2='Pine Forest'. The syntax shown here is for shapefiles, but it can be adapted for any datasource which supports the SQL CONCAT, SUBSTRING and CHAR_LENGTH functions.
  1. Select 'Select by Attributes' from the Selection menu.
  2. Build an expression such as "Field2" LIKE '%[Field1 content]%'.
    Using "Field1" returns the content of Field1 in SQL format which is surrounded by single quotes. The expression needs to extract the literal value of Field1 using SUBSTRING and CHAR_LENGTH:
    SUBSTRING("Field1",1,CHAR_LENGTH("Field1"))
  3. Concatenate the string with % to use it with the LIKE operator:
    CONCAT(CONCAT('%',SUBSTRING("Field1",1,CHAR_LENGTH("Field1"))),'%')
    Note that CONCAT is used twice as it only concatenates two strings at a time.
  4. The final expression will be:
    "Field2" LIKE CONCAT(CONCAT('%',SUBSTRING("Field1",1,CHAR_LENGTH("Field1"))),'%')
Article ID:000007577
Software:
  • ArcMap 8 x
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
