HOW TO
A separate, smaller locator for a certain area of interest can be created from a source StreetMap Premium locator to produce a lightweight locator, geocoding service, or mobile map package. This article describes how to clip a StreetMap Premium for ArcGIS locators to a custom extent in ArcGIS Pro using the Create Mobile Map Package geoprocessing tool.
Note: The described workflow is applicable for classic and new StreetMap Premium locators.
Note: A StreetMap Premium license is required to perform this workflow and to use the newly created locator.
Note: The locator's default location is 'C:\Users\<username>\Documents\ArcGIS\Packages\<packagename>...'. To use only the clipped locator, disable other locators in the project. In the Locate pane, click Settings and uncheck the Enable check boxes for the unnecessary Locate Provider.
The clipped locator can be used independently in other ArcGIS Pro projects and map packages, or published as its own geocoding service. The image below shows a successful search using the clipped locator. Unsuccessful searches that fall outside the clipped locator do not return any results.
Article ID: 000022365
Get help from ArcGIS experts
Start chatting now
