HOW TO
Triangular irregular network (TIN) is a form of vector-based digital geographic data generated from features such as points, lines, and polygons containing elevation information, or by converting other functional surface such as raster or terrain datasets. In ArcMap, it is possible to clip a TIN dataset layer within a polygon feature shapefile.
In this example, a TIN-based surface is clipped based on area of interest using the 3D Analyst extension.
Follow the steps below to clip the area of a TIN using polygon feature in ArcMap:
Note: The Data Management toolset is only available with a 3D Analyst license. To enable the ArcGIS 3D Analyst extension, in the main menu, click Customize > Extensions and check 3D Analyst.
Note: Z-enabled features are not required, as Interpolate Shape tool does not require input feature to be Z-enabled.
Note: Before applying this tool, it is recommended to create a back up copy of the initial TIN to avoid losing information if the editing result is not as desired.
Note: The output TIN layer does not look identical to the input TIN layer along the boundary of the polygon feature shapefile. The boundary of the polygon feature shapefile intersects triangles in the TIN and must be interpolated. If the created polygon feature shapefile is not interpolated, the feature will clip the TIN outside the polygon extent. This results in minor modifications and does not drastically change the surface of the TIN layer.
Article ID: 000022289
Get help from ArcGIS experts
Start chatting now
