HOW TO
Check the count of a choice from a select_multiple question in Survey123 for ArcGIS
Last Published: February 7, 2025
Summary
Survey forms may be designed in Survey123 Connect where a ‘select_multiple’ type question is placed within a Repeat. The Analyze tab in Survey123 website displays the count of a particular survey choice. However, this can also be checked within the survey itself by the following steps.
Procedure
  1. Create a select_multiple type question in the survey sheet inside of a repeat.
    For example:
    • Question - alphabet_select
    • Answer: A, B, C (where, multiple choices can be selected)
  2. Within the repeat, add a calculation to return the value '1' if answer ‘A’ has been selected. For example:
if(selected(${alphabet_select},'A'),'1','0')
  1. Set the bind::type column to int.
  2. Outside the repeat, add a calculation to sum the value from the above question.
Article ID: 000021063
Software:
  • ArcGIS Survey123 Connect
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
