HOW TO
This article describes how check to see if there are duplicate GlobalID values in an Oracle geodatabase. This may have occurred as a result of the problem described in the Knowledge Base article Geodatabase replication synchronization can create duplicate GlobalID values in Oracle.
This script creates a file called c:\temp\dup_glbid_report.txt. Make sure that a c:\temp directory exists, or change directory path in the script.
This script goes through the datasets in each of the versions in the geodatabase. If duplicates are encountered, results similar to following are returned in the report:
Table SDE.BUILDINGS contains 1 duplicate globalid values.
{6CB18410-D7D5-4C29-B0EC-0F3C5C759442}, Count:77
{096C0C25-6C8A-4F16-AFCD-3A64698E5747}, Count:15
The report also includes the total duplicates found at the bottom (for example):
TOTAL DUPLCATES FOUND: 2
If total duplicates found is 0, then no duplicates were encountered.
Article ID: 000012667
Get help from ArcGIS experts
Download the Esri Support App
