HOW TO
Change the theme background color for a survey published from ArcGIS Survey123 Connect
First Published: February 17, 2026
Last Published: March 25, 2026
Summary
In ArcGIS Survey123 Connect, style settings can be configured for survey elements. However, after publishing to ArcGIS Online, the survey form theme background defaults to light green even though the configured style settings are retained. Currently, no option is available in Survey123 Connect to modify the theme background within the survey item configuration.
The default theme of a survey published from ArcGIS Survey123 Connect
This article provides the workflow to edit and set the theme background color of a published survey form in ArcGIS Survey123 web designer.
Procedure
  1. In ArcGIS Online, browse to the My Content page and click Options The Options icon on the published survey form.
  2. Click Manage in Survey123 website.
  3. On the survey form page, click Design.
  4. In the Appearance panel, navigate to the Web page section.
  5. Under Background, ensure Color is selected.
  6. For Select color, click the existing color or the drop-down arrow, and set the desired color.
The Select Color option for the background of the web page
  1. Click Published > Publish.
The theme colors of the survey after being edited in ArcGIS Survey123
Optionally, in the Appearance panel, select the desired theme under Theme. However, this option overwrites the current settings.
Article ID: 000040353
Software:
  • ArcGIS Survey123 Connect
  • ArcGIS Survey123 Website
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
