HOW TO
Change the relative dynamic text scale unit on ArcGIS Pro map layouts
Last Published: July 20, 2023
Summary
In ArcGIS Pro, the dynamic text scale unit on a map layout can be edited by modifying the Dynamic Text settings. This allows the selection and deployment of a suitable relative scale unit for the dynamic text on the map. Adjust the dynamic text scale unit of a map layout in ArcGIS Pro with the steps provided in this article.
Procedure
  1. In the layout view, on the top ribbon, click the Insert tab.
  2. In the Graphics and Text group, click the Dynamic Text The Dynamic Text icon button.
  3. View the current scale unit under Relative Scale. In this example, the scale text shows the relative scale from inches to miles.
The Relative Scale showing the current map layout scale unit
  1. Open the Element pane to view the properties of the text element.
The Format Text pane showing the properties of the text element
  1. In the Format Text pane, under Options, expand Text and click Tag View The Tag View icon to view the dynamic text..
  2. Modify the text element as required. In this example, the 'mapUnits' value is changed to 'feet'.
The Dynamic Text window showing the full dynamic text tags
  1. Click OK.
Article ID: 000025988
Software:
  • ArcGIS Pro 2 8 x
  • ArcGIS Pro 2 7 x
  • ArcGIS Pro 2 x
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
