HOW TO
Change the port numbers ArcIMS uses on UNIX
Summary
ArcIMS uses predefined ports to communicate between the ArcIMS Application Server and the ArcIMS Servlet Connector, and the ArcIMS Application Server and the ArcIMS Spatial Server. The default ports are:· 5300 for communication between the ArcIMS Application Server and the ArcIMS Servlet Connector.· 5353 for communication between the ArcIMS Application Server and the ArcIMS Spatial Server.If there is a conflict with existing ports, it's necessary to change the ArcIMS ports.
Procedure
  1. Edit the following lines in $AIMSHOME/Middleware/Servlet_Connector/Esrimap_Prop:
    Code:
    appServerMachine=APPSMACHINE
    appServerClientPort=5300 **Change port number
  2. Edit the following lines in $AIMSHOME/Middleware/Application_Server/Appserver.Properties:
    Code:
    connectorPort=5300 **Change port number
    regPort=5353 **Change port number
  3. Edit the following line in $AIMSHOME/Monitor/Monitor.properties:
    Code:
    registryPort=5353
    Change the 5353 to the regPort assigned in step 2.
  4. Shut down the ArcIMS Tasker, ArcIMS Monitor, and ArcIMS Application Server processes. Restart your web server. Then start the ArcIMS Application Server, ArcIMS Monitor, and the ArcIMS Tasker processes.
Article ID:000003888
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
