HOW TO
This code sample shows how to change the fill and outline color of features in an ArcGIS Server feature service using an ArcMap add-in. The changes can persist in ArcMap by saving the ArcMap document.
using System;
using System.Collections.Generic;
using System.Text;
using System.IO;
using ESRI.ArcGIS.esriSystem;
using ESRI.ArcGIS.ArcMapUI;
using ESRI.ArcGIS.Geodatabase;
using ESRI.ArcGIS.Carto;
using ESRI.ArcGIS.Geometry;
using ESRI.ArcGIS.Display;
namespace Add_FeatureService_to_ArcMap
public class Add_FeatureService_to_ArcMap : ESRI.ArcGIS.Desktop.AddIns.Button
public Add_FeatureService_to_ArcMap()
protected override void OnClick()
IMxDocument pMx = ArcMap.Application.Document as IMxDocument;
//You may replace this url with your own feature service url. In my case, I have an ArcGIS Server feature service that contains polygon features at the URL shown below:
string url = "https://localhost:6080/arcgis/rest/services/FC1_Polygons/FeatureServer";
IPropertySet pFeatServProp = new PropertySet();
pFeatServProp.SetProperty("DATABASE", url);
IWorkspaceFactory pFeatWorkspaceFact = new FeatureServiceWorkspaceFactory() as IWorkspaceFactory;
IFeatureWorkspace pFeatureWorkspace = pFeatWorkspaceFact.Open(pFeatServProp, 0) as IFeatureWorkspace;
IFeatureClass pfeatClass = pFeatureWorkspace.OpenFeatureClass("0") as IFeatureClass;
// "0" corresponds to the first layer with index/id 0, similarly, "1", "2" refer to layer id 1
// and id 2, you may check the service rest end point to have a valid parameter in the OpenFeatureClass.
IFeatureLayer pfeatLayer = new FeatureLayer();
pfeatLayer.FeatureClass = pfeatClass;
pfeatLayer.Name = "Sami_FC1";
IGroupLayer pGroupLayer = new GroupLayer();
pGroupLayer.Name = "GroupLayerName";
// -------------------------------- RENDERER ---------------------------------------------------
// Creating RGB Colors by pulling values from a Microsoft Color object
System.Drawing.Color c = System.Drawing.Color.FromName("SlateBlue");
IRgbColor rgbColor_Fill = CreateRgbColor(c);
System.Drawing.Color c2 = System.Drawing.Color.FromName("Red");
IRgbColor rgbColor_Outline = CreateRgbColor(c2);
ISimpleLineSymbol simpleLineSymbol_Outline = new SimpleLineSymbol();
simpleLineSymbol_Outline.Color = rgbColor_Outline;
simpleLineSymbol_Outline.Width = 3.0;
ISimpleFillSymbol simpleFillSymbol = new SimpleFillSymbol();
simpleFillSymbol.Style = esriSimpleFillStyle.esriSFSSolid;
simpleFillSymbol.Color = rgbColor_Fill;
simpleFillSymbol.Outline = simpleLineSymbol_Outline;
ISimpleRenderer simpleRenderer = new SimpleRenderer();
simpleRenderer.Label = "Simple Renderer";
simpleRenderer.Symbol = simpleFillSymbol as ISymbol;
IFeatureRenderer featureRenderer = simpleRenderer as IFeatureRenderer;
IGeoFeatureLayer geoFeatureLayer = pfeatLayer as IGeoFeatureLayer;
geoFeatureLayer.Renderer = featureRenderer;
//-------------------------------- END RENDERER ---------------------------------------------------
pGroupLayer.Add(pfeatLayer);
pMx.FocusMap.AddLayer(pGroupLayer);
ArcMap.Application.CurrentTool = null;
// Method used to extract RGB components out of the Microsoft Color object (a structure)
protected static IRgbColor CreateRgbColor(System.Drawing.Color c)
// Note that c is a Microsoft color object, which has 4 components: alpha, R, G, B
// The R, G, B components of the System.Drawing.Color object are assigned to the the ArcObjects IRgbColor object
IRgbColor rgb = new RgbColorClass();
rgb.Red = c.R; rgb.Green = c.G; rgb.Blue = c.B;
rgb.UseWindowsDithering = false;
return rgb;
Article ID: 000013843
Get help from ArcGIS experts
Start chatting now
