HOW TO
Change the default browser for Jupyter Notebook
First Published: June 19, 2020
Last Published: February 10, 2023
Summary
Jupyter Notebook installed with ArcGIS Pro opens notebooks on the default browser set on the machine. However, the default browser can be changed. This is made possible by generating the jupyter notebook config file and modifying the NotebookApp.browser parameter to the executable file of the browser. This article provides the workflow.
Procedure
  1. Open the Python Command Prompt.
  2. Enter the following command to generate the config file:
jupyter notebook --generate-config
  1. Navigate to the following folder location:
cd C:\Users\user\.jupyter
  1. Open the jupyter_notebook_config.py file using a text editor, for example, IDLE or Notepad.
  2. Search for the following parameter:
#c.NotebookApp.browser = ''
  1. Delete the # and insert the executable browser file location. The example below shows the executable Google Chrome browser file location.
c.NotebookApp.browser = '"C:\Program Files\Google\Chrome\Application\chrome.exe" %s'
If the folder location contains a space, insert double quotes to include the full folder location.
  1. Save the file and start Jupyter Notebook.
Article ID: 000023596
Software:
  • ArcGIS Pro
  • ArcGIS API for Python
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
