HOW TO
Change the data source of a layer from referencing a geodatabase to an ArcGIS Server Service URL in ArcGIS Pro using ArcPy
Summary
The data source of a layer in a project references the feature class from the geodatabase physical location on a machine. The dataset can also reference a URL if the dataset is published as an ArcGIS Server service or an ArcGIS Online service. In the ArcPy module, the data source is represented in the 'connectionProperties' dictionary as shown below.
In the geodatabase
{'connection_info': {'database': 'E:\\ArcGIS\\Project\\Database.gdb'},
 'dataset': 'layerXYZ',
 'workspace_factory': 'File Geodatabase'}
In ArcGIS Server Service
{'connection_info': {'url': 'https://sampleserver6.arcgisonline.com/arcgis/rest/services/911CallsHotspot/MapServer'},
 'dataset': '1',
 'workspace_factory': 'FeatureService'}
Procedure
To use the 'connectionProperties' dictionary, import the ArcPy and 'pprint' modules.
The steps below describe how to change the data source of a layer from referencing a geodatabase to a service URL.
  1. Import the necessary modules.
import arcpy, pprint
  1. Specify the project details.
aprx=arcpy.mp.ArcGISProject('current')
map=aprx.listMaps()[0]
l=map.listLayers()[0]
  1. Call the connectionProperties dictionary.
pprint.pprint(l.connectionProperties)
  1. Specify the current data source (geodatabase) dictionary.
Find_dic = {'connection_info':{'database': 'C:\\arcgis\\TEST\\Editing\\Test.gdb'},'dataset': 'Springs','workspace_factory': 'File Geodatabase'}
  1. Specify the service URL dictionary.
replace_dic = {'connection_info':{'url':r'https://services.arcgis.com/Wl7Y1m92PbjtJs5n/arcgis/rest/services/None/FeatureServer'},'dataset': '0','workspace_factory': 'FeatureService'}
  1. Call the updateConnectionProperties() function to update the data source, and save the project file.
l.updateConnectionProperties(Find_dic,replace_dic,True,False,False)
aprx.save()
The following shows the full script.
aprx.save()
The connectionProperties dictionary can also update the service URL. The steps below describe how to do so.
  1. Follow Steps 1 through 3 from the section above.
  2. Define a parameter to store the dictionary.
conProp = l.connectionProperties
  1. Update the URL.
conProp['connection_info']['url'] = r'https://sampleserver6.arcgisonline.com/arcgis/rest/services/EmergencyFacilities/FeatureServer'
l.updateConnectionProperties(l.connectionProperties,conProp)
aprx.save()
p = arcpy.mp.ArcGISProject(r'C:\Projects\YosemiteNP\Yosemite.aprx')
m = p.listMaps()[0]
l = m.listLayers()[0]
aprx.save()
Article ID: 000021613
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
