HOW TO
Change the capabilities of a hosted feature service using ArcGIS API for Python
First Published: January 12, 2022
Last Published: February 2, 2023
Summary
An ArcGIS Server feature service can be configured to include different capabilities for various operations. These capabilities can be selected by accessing the ArcGIS REST Service Directory of the hosted service. Individual layers are accessed through the REST directory and the capabilities of the hosted service are identified through the details listed in the directory.
The image below shows the ArcGIS REST Service Directory page of a feature with full capabilities.
List of capabilities before editing
This article describes the workflow to change the capabilities using ArcGIS API for Python. The script can be run using a stand-alone .py file or Jupyter Notebook.
Procedure
  1. Import the necessary modules.
from arcgis.gis import GIS
from arcgis.features import FeatureLayerCollection
  1. Specify the required credentials and connect to the portal.
gis = GIS('portal url', 'user name', 'password', verify_cert=False)
  1. Search for the service.
search_result= gis.content.search(query="title: Layer Name", item_type="Feature Layer")
test_item= search_result[0]
test_flc = FeatureLayerCollection.fromitem(test_item)
  1. Update the capabilities using an update dictionary.
update_dict = {"capabilities": "Create,Editing,Uploads,Delete,Query"}
test_flc.manager.update_definition(update_dict)
The code block below demonstrates the full script.
gis = GIS('https://domain.esri.com/portal', 'username123', 'password123', verify_cert=False)
search_result= gis.content.search(query="title: Mosaic", item_type="Feature Layer")
update_dict = {"capabilities": "Create,Delete,Query,Update,Editing,Extract"}
The image below shows the changed capabilities after running the script.
The Capabilities after editing
Article ID: 000027057
Software:
  • Portal for ArcGIS
  • ArcGIS Server
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
