HOW TO
Change point colors based on zoom levels in Portal for ArcGIS and ArcGIS Online Map Viewer
First Published: December 27, 2023
Last Published: December 27, 2023
Summary
In Portal for ArcGIS and ArcGIS Online, it may be necessary to dynamically change the colors of point features based on different zoom levels. This is to enhance the interpretability of maps such as contextual information to represent the data density of a location.
This article describes the workflow to change point colors based on zoom levels in Portal for ArcGIS and ArcGIS Online Map Viewer.
Procedure
  1. Open the map containing the point layer in Portal for ArcGIS or ArcGIS Online Map Viewer.
  2. Duplicate the desired point layer. Refer to Portal for ArcGIS: Duplicate a layer or ArcGIS Online: Duplicate a layer for instructions.
  3. Click the duplicated point layer to open its Properties pane.
  4. Under Visibility, set the Visible range to display when the point layer is zoomed out.
Set the visibility range when the point is zoomed out
  1. Specify the symbology color of the point layer. Refer to Portal for ArcGIS: Apply a style or ArcGIS Online: Apply a style for instructions.
  2. Repeat Steps 3 through 5 for the original point layer when the layer is zoomed in.
Set the Visible range when the original point layer is zoomed in
The point colors are changed when the map is zoomed in or out, as demonstrated in the image below.
The point colors are changed when zooming in or out of the map
Article ID: 000031672
Software:
  • ArcGIS Online
  • Portal for ArcGIS
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
