HOW TO
Center a table in the ArcGIS Enterprise portal and ArcGIS Online Map Viewer pop-ups
First Published: January 24, 2025
Last Published: February 25, 2025
Summary
In Map Viewer in the ArcGIS Enterprise portal and ArcGIS Online, a table in a pop-up is left-aligned by default, which makes the information appear unbalanced or visually less appealing. HTML formatting can be used to center the table, improving readability and enhancing presentation quality.
The image below shows the table is left-aligned by default in a pop-up.
The table is left-aligned by default in the ArcGIS Enterprise portal and ArcGIS Online Map Viewer pop-up
This article provides the workflow to center a table in the ArcGIS Enterprise portal and ArcGIS Online Map Viewer pop-ups.
Procedure
  1. Log in to the ArcGIS Enterprise portal or ArcGIS Online and open the web map in Map Viewer.
  2. In Map Viewer, on the Settings toolbar, click Pop-ups The Pop-ups icon.
  3. In the Pop-ups pane, click Add content, and select Text.
  4. In the text editor, click Source The Source icon.
  5. Configure the HTML codes.
    • This method only applies in ArcGIS Online.
<div style="display:flex; justify-content:center;">
    • This method applies in both the ArcGIS Enterprise portal and ArcGIS Online.
<table style="border-collapse: collapse; margin: auto;">
    The code block below shows the example of the full working script in the ArcGIS Enterprise portal and ArcGIS Online:
    <div>
        <figure class="table">
                <tbody>
                    <tr>
                        <td style="border: 2px solid #f47735; padding: 5px;">
                            <p style="margin: 0; text-align: left;">
                                <span style="color: #005daa;"><strong>Object ID: {OID}</strong></span>
                            </p>
                        </td>
                    </tr>
                    <tr>
                            <span style="color: #005daa;"><strong>ID: </strong></span><span>{ID}</span><br>
                            <span style="color: #005daa;"><strong>Nearest Feature ID: </strong></span><span>{NEAR_FID}</span><br>
                            <span style="color: #005daa;"><strong>Nearest Distance: </strong></span><span>{NEAR_DIST} meters</span><br>
                            <span style="color: #005daa;"><strong>Nearest X Coordinate: </strong></span><span>{NEAR_X}</span><br>
                            <span style="color: #005daa;"><strong>Nearest Y Coordinate: </strong></span><span>{NEAR_Y}</span>
                        </td>
                    </tr>
                </tbody>
            </table>
        </figure>
    </div>
    1. Click Source. The table is displayed in the text editor.
    2. Click OK to close the text editor.
    3. On the Contents toolbar, click Save and open > Save to save the modifications.
    The image below shows the table is centered in the ArcGIS Enterprise portal and ArcGIS Online Map Viewer pop-up.
    The table is centered in the ArcGIS Enterprise portal and ArcGIS Online Map Viewer pop-up
    Article ID: 000034672
    Software:
    • ArcGIS Online
    • Portal for ArcGIS
    • ArcGIS Enterprise
    Get support with AI
    Start chatting now
    Related Information
    Discover more on this topic
    Get help from ArcGIS experts
    Contact technical support
    Start chatting now
    Go to download options
