HOW TO
Calculate the total number of fields in a feature class using Python ListFields() in ArcGIS Pro
First Published: April 30, 2020
Last Published: July 21, 2023
Summary
In ArcGIS Pro, the Get Count geoprocessing tool is used to calculate the total number of rows in an attribute table. However, this tool does not calculate the total number of columns, which represents the total number of fields in a feature class.
Providing a method to calculate this is helpful when there is a large number of attributes in a feature class. This is achieved using the Python ListFields() function.
An attribute table of a feature class.
Procedure
Follow the workflow below to calculate the total number of fields in a feature class using the Python ListFields() function.
  1. In ArcGIS Pro, on the Analysis tab, click the down arrow next to Python, and select Python window.
the Analysis tab and the drop-down menu of the Python button. Python Notebook and Python window are listed in the drop-down menu.
  1. In the Python window, in the prompt section, enter the Python ListFields() function as shown below. Refer to ArcGIS Pro: ListFields for more information.
import arcpy
fields = arcpy.ListFields('Feature Class Name')
print(len(fields))
Do not remove the single quotation marks enclosing the feature class name.
In this example, the feature class is Asia.
The Python window prompt section.
  1. Place the cursor at the end of the expression and press Enter twice on the keyboard. The image below shows the total number of fields for the Asia feature class is 8.
The Python window with the result after executing the ListField funtion.
Article ID: 000023096
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
