HOW TO
Calculate the total number of fields in a feature class using Python ListFields() in ArcMap
First Published: January 12, 2020
Last Published: July 20, 2023
Summary
In ArcGIS Desktop, the Get Count geoprocessing tool is used to calculate the total number of rows in an attribute table. However, this tool does not calculate the total number of columns, which represent the total number of fields in a feature class.
Calculating the total number of fields is useful when there are a number of attributes in a feature class. The total can be derived using the Python ListFields() function.
Table showing a number of attributes
Procedure
The workflow below describes how to calculate the total number of fields in a feature class using the Python ListFields() function.
  1. In ArcMap, click the Geoprocessing tab, and select Python to open the Python command window.
ArcMap Geoprocessing tab and window
  1. In the Python window, enter the Python ListFields() function.
print len(arcpy.ListFields(r"location of your feature class or shapefile","*"))
For more information on the function, refer to ArcMap: ListFields.
In this example, the following expression is used to count the fields in the Counties feature class:
print len(arcpy.ListFields(r"C:\Users\*****\Desktop\Data2\State.gdb\Counties","*"))
Fields in the Counties feature class
  1. Place the cursor at the end of the expression and press Enter. The image below shows the total number of fields for the Counties feature class is 5.
Total number of fields is 5
Article ID: 000022586
Software:
  • ArcMap
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
