HOW TO
Calculate the area of a vector dataset based on raster values using the Tabulate Area tool
First Published: January 25, 2021
Last Published: March 16, 2021
Summary
ArcGIS Pro can calculate the area of a vector dataset using raster values with the Tabulate Area tool. For example, the area of land use categories by districts can be calculated using the raster values relative to a vector dataset to understand the impact of population growth in the city.
Depending on the dataset size, calculating the area of a vector dataset using raster values may consume a lot of time and computer memory.
Procedure
This workflow describes how to calculate the area of land use from a land use raster relative to the feature class of country subdivisions in Puerto Rico using the Tabulate Area tool.
The Spatial Analyst extension must be installed and enabled to use the Tabulate Area geoprocessing tool. Refer to ArcGIS Pro: Enabling the Spatial Analyst extension for more information.
  1. In ArcGIS Pro, add the classified land use dataset. This is a raster dataset classified in 10 classes.
  2. Add the country subdivisions polygon shapefile. This is a vector dataset.
  3. On the Analysis tab, click the Tools icon in the Geoprocessing group to open the Geoprocessing pane.
  4. In the Geoprocessing pane, search for and select the Tabulate Area Tool.
  5. In the Tabulate Area pane, set the parameters.
    1. For Input raster or feature zone data, select the land use raster dataset added in Step 1.
    2. The Zone field is set to Value by default.
    3. For Input raster or feature class data, select the country subdivision polygon shapefile added in Step 2.
    4. For Class field, select the field name from the polygon shapefile. This field is used to calculate the area of the raster dataset.
    5. For Output table, specify the output geodatabase or folder for the output table.
    6. Click Run.
The Tabulate Area geoprocessing pane with all the parameters to calculate the area of the raster dataset using a field from the vector dataset
To determine the area of each class per zone, check the Classes as rows in output table check box.
  1. The Output table is added in the Content pane. Right-click on the resulting output table to examine the contents. The area in square meters of the land use by pixel counts is calculated for each type of land use for each country subdivision.
Comparison of the output tables when Class as rows in output table is checked on the left and unchecked on the right
Article ID: 000024857
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
