HOW TO
Calculate shadow lengths using Arcade in the ArcGIS Enterprise portal and ArcGIS Online
First Published: February 13, 2025
Last Published: February 13, 2025
Summary
Shadow analysis such as calculating shadow lengths plays a crucial role for urban planning and environmental studies. For instance, in urban planning, calculating shadow lengths can help determine the optimal placement of new buildings to prevent casting long shadows over public parks, ensuring they receive adequate sunlight for recreational use.
This article provides the workflow to calculate shadow lengths using Arcade in the ArcGIS Enterprise portal and ArcGIS Online.
Procedure
  1. Log in to the ArcGIS Enterprise portal or ArcGIS Online and click Content > My Content.
  2. Click the hosted feature layer to open the item page.
  3. Add a new string field. Refer to Portal for ArcGIS: Add a field or ArcGIS Online: Add a field for instructions. In this example, a new field, 'ShadowGeometry', is added to the attribute table with three existing fields named 'Building_Height', 'SunAltitude', and 'SunAzimuth' respectively.
  4. Open the Arcade window. Refer to Portal for ArcGIS: Calculate values for a field from the item page or ArcGIS Online: Calculate values for a field from the item page for instructions.
  5. In the Expression box, specify the following Arcade expression:
    1. Input the necessary fields and variables.
var buildingHeight = $feature.Building_Height;
var sunAltitude = $feature.SunAltitude;
var sunAzimuth = $feature.SunAzimuth;
    1. Check for valid values.
if (IsEmpty(buildingHeight) || IsEmpty(sunAltitude) || IsEmpty(sunAzimuth) || sunAltitude <= 0) {
  return null;
    1. Convert degrees to radians.
var toRadians = PI / 180;
var sunAltitudeRadians = sunAltitude * toRadians;
    1. Calculate the shadow length using the tangent function.
var shadowLength = buildingHeight / Tan(sunAltitudeRadians);
    1. Return the shadow length and direction as a string.
return "Length: " + Round(shadowLength, 2) + " meters, Azimuth: " + Round(sunAzimuth, 2) + " degrees";
The code block below shows the example of the full working script:
    return null;
  1. Click OK.
The attribute table below shows the calculated shadow lengths in the 'ShadowGeometry' field.
The calculated shadow lengths in the attribute table
Article ID: 000034650
Software:
  • ArcGIS Online
  • Portal for ArcGIS
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
