HOW TO
Calculate length of 2D lines considering elevation
Last Published: November 24, 2022
Summary
This article provides the steps to calculate the length of lines that are created with Z-values disabled, using elevation values from a surface or raster. The resulting length includes the vertical distance between two points.
Procedure
Taking into account that 2D lines do not have Z-values, they must be converted into a 3D layer to be used to calculate the length.
The Interpolate Shape tool requires either the 3D Analyst or Spatial Analyst license, while the Add Z Information tool requires a 3D Analyst license.
  1. In ArcGIS Pro, open the Geoprocessing pane.
  2. Search for the Interpolate Shape tool.
  3. Select the 2D line and surface as the inputs. In this example, a TIN was used as a surface, as shown in the next image.
  1. Run the tool and if needed, drag the output layer to the 3D Layers group in the Contents pane.
  2. In the Geoprocessing pane, search for the Add Z Information tool.
  3. Select the new line 3D layer, the 3-Dimensional Length output property and click Run.
  1. Open the attribute table to find a new field with the 3D length. The attribute table below shows the difference in length when the elevation is considered.
You may consider using the Add Surface Information tool to calculate the length of 2D lines considering elevation values from a surface or raster. Please note that this tool ignores by default the Z values of the 3D features if used as input.
Article ID: 000028286
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
