HOW TO
Starting with ArcGIS Pro 2.2, the 'Calculate Geometry Attributes' geoprocessing tool was added to generate geometry attributes on a field. This tool can be accessed from within a context menu in the attribute table or the geoprocessing pane.
The instructions provided describe how to calculate geometry in ArcGIS Pro.
Note: Certain fields are inherent fields of the feature class managed by the geodatabase, for example, in a polygon feature class, there are four fields that are unavailable for editing; OBJECTID, Shape, SHAPE_LENGTH, and SHAPE_AREA. The Calculate Geometry option is unavailable for these fields.
Note: The Calculate Geometry tool only provides coordinates in the coordinate system assigned to the data. if coordinates in Degrees Decimal Minutes (DDM), Degrees Minutes Seconds (DMS), or MGRS or US National Grid are needed, use the Convert Coordinate Notation tool in ArcToolbox: Data Management Tools > Projections and Transformations > Convert Coordinate Notation.
Article ID:000016157
Get help from ArcGIS experts
Download the Esri Support App
