HOW TO
The instructions provided below describe how to calculate values from an existing field to a newly created field using the Add Field and Field Calculator tools in ArcMap.
![[O-Image]](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000012493/00N39000003LL2C-0EM39000000wdeU.png)
![[O-Image]](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000012493/00N39000003LL2C-0EM39000000wdeX.png)
For more information on field data types, refer to the following document: ArcGIS Help: ArcGIS field data types.
B. Use the Field Calculator to calculate values from an existing field to the new field.
1. Right-click the layer or table to be edited and open the attribute table. ![[O-Image]](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000012493/00N39000003LL2C-0EM39000000wdeZ.png)
2. Right-click the field heading for the field that was added above, and click the Field Calculator.
3. In the Field Calculator, use the Fields list and Functions to build a calculation expression. In this case, add the field containing the values to be copied over to the new field to enable the name to display in the expression block.
4. Click OK to run the tool. ![[O-Image]](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000012493/00N39000003LL2C-0EM39000000wdeW.png)
Article ID: 000012493
Get help from ArcGIS experts
Start chatting now
