HOW TO
Calculate a distance from a known point to a series of polygon centroids
Summary
You can use Avenue to calculate a distance from a known point to a series of polygon centroids. This is an example of coding using the Avenue requests: ReturnCenter, GetX, GetY, and SqRt.
Procedure
  1. Open a New Script window.
  2. Copy and paste this code:
    Code:
    '-- Calculating Distance Script
    '-- This script requires:
    '-- 1. A polygon theme in the view
    '-- 2. A field called 'zipcode' in the attribute table
    TheView = av.GetActiveDoc
    theThm = theView.GetActiveThemes.Get(0)
    thl = theThm.GetFtab
    thl.SetEditable(TRUE)
    if (thl.FindField("zipcode") = nil) then
    MsgBox.Error("zipcode field does not exist","")
    exit
    end
    '-- Get search point location
    fldval = MsgBox.Input("Enter the Target ZipCode","Target ZipCode","")
    MsgBox.Info(fldval,"")
    s = 0
    zipfld = thl.FindField("zipcode")
    shpfld = thl.FindField("shape")
    found = "no"
    for each n in thl
    if ((thl.ReturnValue(zipfld,s).AsString = fldval)) then
    poly = thl.ReturnValue(shpfld,s)
    polps = poly.ReturnCenter
    xcord = polps.GetX
    ycord = polps.GetY
    found = "yes"
    end
    s = s + 1
    end
    if (found = "no") then
    MsgBox.Error("Can't find the Zip id you entered","")
    exit
    end
    '-- Check for the existence of fields
    fldnames = thl.GetFields
    count = 0
    for each x in fldnames
    if (x.AsString = "xcord") then
    count = count + 1
    end
    if (x.AsString = "ycord") then
    count = count + 1
    end
    if (x.AsString = "Distance") then
    count = count + 1
    end
    end
    if ((count = 1) or (count = 2)) then
    MsgBox.Error("The file "+thl.AsString+"+NL+
    some but not all of the fields needed. You must create them manually","")
    exit
    end
    if (count = 3) then
    xcords = thl.FindField("xcord")
    ycords = thl.FindField("ycord")
    Dist = thl.FindField("Distance")
    end
    '-- Create the xcord, ycord, Distance fields and add them to shape file
    if (count <> 3) then
    xcords = Field.Make("xcord",#FIELD_DECIMAL,16,6)
    ycords = Field.Make("ycord",#FIELD_DECIMAL,16,6)
    Dist = Field.Make("Distance",#FIELD_DECIMAL,16,6)
    FldLst = {xcords,ycords,Dist}
    thl.AddFields(FldLst)
    end
    n = 0
    '-- Perform field calculations
    plyFtab = Thethm.GetFtab.FindField("shape")
    for each n in thl
    '-- Find the shape field and return its value "polygon"
    what = theThm.getFtab.ReturnValue(plyFtab,n)
    '-- Get the x and y value of the centers of each polygon
    pnts = what.ReturnCenter
    xnum = pnts.GetX
    ynum = pnts.GetY
    '-- Set the x and y of the center to a record number
    theThm.GetFtab.SetValue(xcords,n,xnum)
    theThm.GetFtab.SetValue(ycords,n,ynum)
    '-- Calculate the distance for the search point and the
    '-- centroid of the polygons and set that value in the distance field
    calnum = (((xnum - xcord)^2) + ((ynum - ycord)^2)).SqRt
    theThm.GetFtab.SetValue(Dist,n,calnum)
    n = n + 1
    end
    '-- End of Script
    The script will:
    a. Prompt you to enter the zipcode ID.
    b. Initiate a search from the center of the target polygon.
    c. Create three fields to store information.
    d. Calculate the distance from the point entered and the centroids of the each polygon.
    e. Set the calculated value to the distance field.
  3. Make view active, then compile and run the script.
Article ID:000002458
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
