HOW TO
Build pyramids for raster data using VBA
Summary
VBA code can loop through all the raster datasets in the specified workspace and build pyramids if necessary.
Procedure
  1. Use a RasterWorkspaceFactory object to create a pointer to the location of the raster data.
    Dim pWorkspaceFactory As IWorkspaceFactory
    Dim pWorkspace As IWorkspace
    Dim pRasterDataset As IRasterDataset
    Dim pEnumDataset As IEnumDataset
    Set pWorkspaceFactory = New RasterWorkspaceFactory
    Set pWorkspace = pWorkspaceFactory.OpenFromFile("d:\data\raster", 0)
  2. Loop through all the raster datasets in the workspace and if pyramids are not present build them.
    Set pEnumDataset = pWorkspace.Datasets(esriDTRasterDataset)
    Set pRasterDataset = pEnumDataset.Next
    Do Until pRasterDataset Is Nothing
    'QI for IRasterPyramid from IRasterDataset
    Dim pRasterPyramid As IRasterPyramid
    Set pRasterPyramid = pRasterDataset
    If pRasterPyramid.Present = False Then
    pRasterPyramid.Create
    MsgBox "Created Pyramid for " & pRasterDataset.CompleteName
    Else
    MsgBox "Pyramid already exists for " & pRasterDataset.CompleteName
    End If
    Loop
Article ID:000002407
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
