HOW TO
Batch update sharing level of ArcGIS Online or Portal for ArcGIS items using ArcGIS API for Python version 2.3 and prior
First Published: December 28, 2023
Last Published: July 28, 2025
Summary
The sharing level of Portal for ArcGIS items can be changed to restrict or allow access according to the intended purpose of the items. The sharing level can be changed by following the steps provided in the following documentation, ArcGIS Online: Share items. However, sharing multiple items with an organization can be time-consuming if performed manually. This article provides a simplified procedure using ArcGIS API for Python to change the sharing level in bulks for different scenarios.
Procedure
The following script can be run on ArcGIS Notebook or as a stand-alone script.
Update the sharing level of multiple items by specifying the item IDs
  1. Import the necessary modules.
import arcgis
from arcgis.gis import GIS
from arcgis.gis import User
  1. Connect to the account and specify the credentials.
gis = GIS('https://<machine>.<domain>/<web adaptor name>/home', 'username', 'password', verify_cert=False)
print ('Connected')
  1. Specify the item IDs and the group name, if applicable, to be updated.
items_list = ['<itemID1>', '<itemID2>', '<itemID3>', '<itemID4>', '<itemID5>']
  1. Iterate through all the items and change the sharing level using the share() function.
for item in items_list:
    ids = gis.content.get(item)
    #To make the item public
    ids.share(everyone = True, allow_members_to_edit = True)
    #To share the item within organization
    ids.share(org = True, allow_members_to_edit = True)
    #To share the item within groups
    ids.share(groups = '<group id>', allow_members_to_edit = True)
    #To set only for owner
    ids.share(groups = '', org=False, everyone=False, allow_members_to_edit = False)
The code block below shows the full script to change the sharing level to everyone.
import arcgis
gis = GIS('https://test.esri.com/arcgis/home', 'username1', 'password1', verify_cert=False)
print ('Connected')
items_list = ['as65f468ae1s6a5f', 'sdv91sr1c651re6v', '5a1ec81rgsadf65v', 'sad1vr98ea165sd1f']
Update the sharing level of items based on the file type
import arcgis
print ('Connected')
  1. Search for the items based on the specified file type. Available file types are described in the following documentation, ArcGIS Developer: Items and item types. The following line demonstrates Shapefile as the file type selected.
items_list = gis.content.search('', item_type='Shapefile', max_items=-1)
The code block below shows the full script to change the sharing level to a group for Portal for ArcGIS.
import arcgis
print ('Connected')
Change the sharing level of items owned by a username
import arcgis
print ('Connected')
  1. Search for all items owned by the username.
items_list = gis.content.search(query = 'owner:<username>', max_items=-1)
The code block below shows the full script to change the sharing level within the organization for ArcGIS Online.
import arcgis
print ('Connected')
items_list = gis.content.search(query = 'owner:user1', max_items=-1)
    ids.share(groups = 'daw3rqwd4fr3qfeq3c', allow_members_to_edit = True)G
Change the sharing level of all the items in a specific folder
import arcgis
print ('Connected')
  1. Get the specific folder names.
user = gis.users.get('<username>')
items_list = user.items(folder='<folder_name>', max_items=-1)
The code block below shows the full script to change the sharing level to everyone for Portal for ArcGIS.
import arcgis
print ('Connected')
Article ID: 000031704
Software:
  • Portal for ArcGIS
  • ArcGIS API for Python
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
