HOW TO
Auto-refresh a feature layer periodically using the ArcGIS API for JavaScript
First Published: June 10, 2016
Summary
The base class for all layers in ArcGIS API for JavaScript 3.x provides a 'refreshInterval' property, which allows the layer to automatically refresh at the set interval.
The following instructions describe how to auto-refresh a feature layer periodically using ArcGIS API for JavaScript 3.20. All classes that inherit from the base class Layer have access to the refreshInterval property and the setRefreshInterval() method. Hence, the refresh interval can be set on a graphics layer and a dynamic map service layer the same way.
Procedure
There are two ways of setting the feature layer's refresh interval:
  • The first option is to set the refresh interval property on a feature layer by calling the setRefreshInterval(interval) method using the following script:
var featureLayer = new
FeatureLayer("https://sampleserver6.arcgisonline.com/arcgis/rest/services/Wildfire/FeatureServer/0");
featureLayer.setRefreshInterval(1); //Set the interval to 1 minute
map.addLayer(featureLayer);
    • The second option is to set the refreshInterval property when instantiating a feature layer by applying the property in the layer object using the following script:
    var featureLayer = new FeatureLayer("https://sampleserver6.arcgisonline.com/arcgis/rest/services/Wildfire/FeatureServer/0", {
       mode: FeatureLayer.MODE_ONDEMAND,
       refreshInterval: 1, //Set the interval to 1 minute
    The refreshInterval property enables a timer for the set interval and the client requests new features based on the used to add the feature layer.
    For more information on the setRefreshInterval(interval) method and refreshInterval property, refer to the following web help documents:
    Article ID: 000013384
    Software:
    • ArcGIS API for JavaScript
    Get support with AI
    Start chatting now
    Related Information
    Discover more on this topic
    Get help from ArcGIS experts
    Contact technical support
    Start chatting now
    Go to download options
