HOW TO
Auto-populate attribute field with values of intersecting features using attribute rule in ArcGIS Pro
First Published: September 12, 2023
Last Published: February 27, 2026
Summary
In ArcGIS Pro, it is possible to copy field values from one feature to another. When working on a project involving continuous data collection, feature classes may intersect and share the same field values, and attribute rules allow users to auto-populate the attribute fields of newly created features with the values of the intersecting feature classes. This method is useful in data management and spatial analysis.
In this article, an attribute rule is applied to auto-populate the Location field (from the Lot point feature class) with the values of the Name field (from the Zone polygon feature class) when both the feature classes intersect. The attribute table for the Zone polygon feature is shown below.
Both intersecting features must have the same coordinate system to populate the attribute field value.
Procedure
  1. Open the ArcGIS Pro project.
  2. In the Catalog pane, browse to and right-click the feature class and click Manage. In this example, the Lot point feature class is selected.
  3. In the Feature Class Properties window, in the Manage section, check the Global IDs check box and click OK.
Enabling the Global IDs for the feature layer
The dataset requires Global IDs to add an attribute rule.
  1. Right-click the feature layer in the Contents pane and click Data Design > Attribute Rules. In this example, the Lot feature is selected.
  2. Click the Add Rule drop-down list and select Immediate Calculation.
  3. Specify the Rule Name. In this example, New Rule is used.
  4. For Field, select the field to use. In this example, Location is used.
  5. Insert and configure the expression below in the Expression box.
var <variable_name> = FeatureSetByName($datastore, "<feature_layer>")
for( var f in <variable_name>){
if(Intersects($feature, f)){
return f.Name}
  1. Replace <feature_layer> with the name of the feature layer intersecting the newly created features. In this example, the polygon layer named Zone is used.
  2. Replace <variable_name> with the preferred name. In this example, 'intersectline' is used.
  1. Under Triggers, check the preferred option. In this example, Insert and Update are checked.
  2. On the Attribute Rules tab, in the Manage Edits group, click Save.
The Attribute Rules configuration window
The attribute table below shows the Location field of the Lot point feature layer being populated with values from the Name field of the Zone polygon feature layer when both the feature layers intersect on the map.
The Point attribute table populated by values of intersecting polygon features
Article ID: 000031093
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
