HOW TO
Authorize ArcGIS Pro and extensions offline for single use licensing
Last Published: October 6, 2025
Summary
Some customers require ArcGIS Pro to work on a machine that is not connected to the internet. In these cases, they cannot authorize ArcGIS Pro by connecting to My Esri through the machine. To work around this, an offline authorization must be completed. This involves creating an authorization.txt file and uploading it to My Esri using Secure Site Operations. This provides the user an authorization.respc file that can be used to authorize ArcGIS Pro on a machine that does not have access to the internet or is highly constricted.
Procedure
To start the offline authorization process for single use, follow these steps:
  1. Start ArcGIS Pro on the machine that requires the licenses. Go to the Licensing tab and choose Configure your licensing options.
Licensing tab in ArcGIS Pro
  1. In the Licensing window, for License Type, choose Single Use License, select the needed License Level, and click Authorize
Selecting the license type and level
  1. The Software Authorization Wizard opens. In the Authorization Options box, choose I have installed my software and need to authorize it. Click Next
indicate that the software is installed
  1. In the next step, choose Authorize at Esri's website or by email to receive your authorization file. Click Next
Selecting the authorization method
  1. Fill out the appropriate user information. This may already be filled out automatically. After entering the required information, click Next.
  2. Enter the authorization number (ESU) for the level of ArcGIS Pro single use license that is needed: Advanced, Standard, or Basic.
    • This can be found in My Esri by going to Licensing > Authorizations, and searching for "ArcGIS Pro". After the number is entered, including ESU, click Next
To also authorize any single use extension licenses for ArcGIS Pro at this time, follow the previous steps to find the ESU number. If the desired extension is not listed in the Feature column, enter the name of it using the keyboard under the last listed extension, making sure all the characters match exactly as they are listed on My Esri. Click Next.
  1. The Email Authorization step in the wizard should be open. Click Save. The wizard prompts to choose a location to save the authorization.txt file. This file is used on My Esri to create the needed file. If the current machine does not have the ability to access My Esri with the correct permissions, move the file to a machine that does.
saving the authorization.txt file
  1. Go to My Esri on a machine that has access to it and the correct permissions. Go to the Licensing tab, under Additional Licensing Tools, click Secure Site Operations
selecting the license permissions submtting the authorization.txt file
  1. On the Secure Site Operations page, click Select file and use the authorization.txt file created previously. Click Submit. After the tool is done loading, the authorization.respc file is downloaded.
finishing the authorization
  1. If necessary, move this file to the machine that requires ArcGIS Pro licensing. Open ArcGIS Pro, and open the Software Authorization Wizard again. This time, choose I have received an authorization file and am now ready to finish the authorization process. Click Browse and choose the authorization.respc file. If extensions are added to the list of authorizations, this step should be the same.  Click Next
authorization processing
  1. The file is then processed. A checkmark should appear once completed. Click Finish
product now authorized
In the Licensing window, ArcGIS Pro should now be licensed.
Article ID: 000037720
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
