HOW TO
Use Arcade Expressions to Reformat a Date in a Dashboards List Element
First Published: December 29, 2025
Last Published: December 29, 2025
Summary
Arcade expressions can be used for dynamic calculation and formatting within list elements in ArcGIS Dashboards. The following outlines how to set up an expression to convert and reformat a date field from the Configure options of a list element.
Procedure
In ArcGIS Online or ArcGIS Enterprise, access ArcGIS Dashboard and configure the list element.
  1. Open the ArcGIS Dashboards item in edit mode.
  2. From the List element, hover over Options and click Configure.
  3. Click the List tab and click Enable next to Advanced formatting.
  4. Specify the following code in the Advanced formatting Expression text box:
    var OriginalDate= $datapoint.DateReported
    var UTCDate= ChangeTimeZone(OriginalDate, 'UTC')
    var FormattedUTCDate= Text(UTCDate, "ddd DD MMM YYYY, hh:mm a")
return {   textColor: '',   backgroundColor: '',   separatorColor:'',   selectionColor: '',   selectionTextColor: '',   attributes: {     Date: FormattedUTCDate    } }
  1. Add "{expression/Date}" into the Template text box.
  2. Click Done.
Article ID: 000037608
Software:
  • ArcGIS Online
  • ArcGIS Enterprise
  • ArcGIS Dashboards
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
