HOW TO
Apply pop-up configurations to another feature layer in ArcGIS Pro
First Published: September 27, 2024
Last Published: September 27, 2024
Summary
In ArcGIS Pro, the pop-up for each feature layer is configured to display the feature's attributes and provide additional details. At times, it is necessary to apply the same pop-up configuration to multiple layers to present information in a similar structure and enable seamless comparison between layers. Although there is no tool to import only the pop-up settings of a feature layer, it is possible to replicate the pop-up configuration.
This article describes two workflows to apply pop-up configurations to another feature layer in ArcGIS Pro.
Procedure
Import the feature layer’s symbology to import the pop-up configuration
Pop-up configurations are integrated with other layer properties, such as symbology and label class, within a layer file (.lyrx). To import a pop-up configuration, save the feature layer with the desired pop-up configuration as a layer file, then import the layer’s settings into the target feature layer. Refer to ArcGIS Pro: Save a layer file and ArcGIS Pro: Import symbology to a feature layer for further instructions.
When using the Apply Symbology From Layer tool, the layer’s symbology and label class are also transferred. To copy only the pop-up configuration, change the target layer’s symbology and label class to differentiate the layer from the symbology layer. Refer to ArcGIS Pro: Apply symbology to feature layers and ArcGIS Pro: Use label classes for instructions.
Copy the HTML code or Arcade expressions of the pop-up elements
When working with similar layers or datasets, the pop-up configuration can be transferred to another feature layer by copying the HTML code or custom Arcade expressions of the pop-up elements.
  1. Open the ArcGIS Pro project.
  2. Copy the HTML code or Arcade expressions of the pop-up elements.
    1. In the Contents pane, right-click the feature layer and select Configure Pop-ups.
    2. In the Configure Pop-ups pane, hover over the preferred pop-up element and click the Edit pop-up element button The Edit pop-up element icon.. In this example, the Fields(2) element is hovered over.
The pop-up elements in the Configure Pop-ups pane.
  1. Toggle on the HTML mode toggle button. When prompted, click Yes.
Arcade expressions can be copied from the Arcade element in the Expression section.
  1. Highlight all the text in the Text Options pane. Right-click the highlighted text and select Copy to copy the HTML code.
  2. Click Back The Back icon..
  1. Paste the HTML code or Arcade expressions to another feature layer.
    1. In the Contents pane, right-click the feature layer to apply the HTML code or Arcade expressions and select Configure Pop-ups.
    2. In the Configure Pop-ups pane, click the Fields element to add the same pop-up element as in Step 2b.
    3. Click the Edit pop-up element button The Edit pop-up element icon.on the pop-up element.
    4. Toggle on the HTML mode toggle button. When prompted, click Yes.
    5. Remove the existing text in the Text Options pane. Right-click and select Paste to paste the copied HTML code.
    6. Click Back The Back icon. to apply the pop-up configuration.
  1. Repeat Steps 2 and 3 to copy and paste the HTML code or Arcade expressions of other pop-up elements.
The image below shows the pop-up configuration from the CCTV_North layer applied to the CCTV_Northeast layer.
The copied pop-up configuration applied to another feature layer.
Article ID: 000033629
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
