HOW TO
Apply Grayscale to specific rasters in a mosaic dataset in ArcGIS Pro
First Published: March 12, 2025
Last Published: March 12, 2025
Summary
In ArcGIS Pro, mosaic datasets are commonly used to manage large collections of raster datasets. When working with mosaic datasets, applying raster functions is a standard practice to enhance visualization and analysis. One such function is Grayscale, which converts a multiband raster into a single-band grayscale image by applying specified weights to the red, green, and blue (RGB) channels.
This article provides the workflow to apply the Grayscale function only to a specific raster within a mosaic dataset. This approach is particularly useful when a dataset contains various image sources, but only certain rasters require the grayscale conversion.
The map displaying the mosaic dataset with colored imagery below is used to demonstrate the workflow.
The mosaic dataset with colored imagery datasets
Procedure
  1. Open the project in ArcGIS Pro.
  2. Use the Explore Raster Items to filter the raster datasets in the mosaic dataset and select only the desired raster to be converted into a grayscale image. Refer to ArcGIS Pro: Raster Item Explorer for instructions.
  3. In the Raster Item Explorer pane, on the Inspect tab, click Item Functions Item Functions icon to open the Raster Function Editor window.
  4. In the Raster Function Editor window, click Raster Functions Raster Functions icon.
  5. In the Raster Functions pane, click System > Conversion and drag Grayscale into the Raster Function Editor window. Refer to ArcGIS Pro: Access the Function Editor for more information.
The Raster Functions pane
  1. In the Raster Function Editor window, click RasterInfo and drag the handle to Grayscale to connect the elements.
The Function Editor pane
  1. Click Validate Validate icon and click Apply The Apply icon.
The map below displays the single raster in grayscale within the mosaic dataset.
Only one raster dataset displayed as a grayscale
Article ID: 000034871
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
