HOW TO
Apply commas between two or more values in a list with Arcade in ArcGIS Dashboards
First Published: August 9, 2023
Last Published: August 5, 2026
Summary
ArcGIS Arcade expressions can be used in ArcGIS Dashboards to customize how the data points appear in the list element.
This article provides the steps to apply commas between two referenced field values, CITY and DISTRICT, with Arcade in ArcGIS Dashboards.
Shown below is the list element without the Arcade expression.
An example of the List element without the Arcade expression enabled
Procedure
  1. Open the ArcGIS Dashboards item. Click View on the dashboard toolbar and click Options The horizontal ellipsis icon, found next to the element. Click Configure.
The dashboard toolbar with the View tab
  1. Click List to open the List options menu, and click Enable.
The advanced formatting of the List element in ArcGIS Dashboards
  1. Under Advanced formatting, specify the following Arcade expression.
// Edit the desired variable name and required field name accordingly
var <variableName1> = IIF(IsEmpty($datapoint.<fieldName1>), '', $datapoint.<fieldName1>)
var <variableName2> = IIF(IsEmpty($datapoint.<fieldName2>), '', $datapoint.<fieldName2>)
var <variableName3> = IIF((IsEmpty($datapoint.<fieldName1>)) ||(IsEmpty($datapoint.<fieldName2>)), '', ',')
var <variableName4> = <variableName1> + <variableName3> + ' ' + <variableName2>
return {
  textColor: '',
  backgroundColor: '',
  separatorColor:'',
  selectionColor: '',
  selectionTextColor: '',
  attributes: {
   <variableName4>: <variableName4>
The code block below demonstrates the full working expression.
var city = IIF(IsEmpty($datapoint.CITY), '', $datapoint.CITY)
var district = IIF(IsEmpty($datapoint.DISTRICT), '', $datapoint.DISTRICT)
var comma = IIF((IsEmpty($datapoint.CITY)) ||(IsEmpty($datapoint.DISTRICT)), '', ',')
var location = city + comma + ' ' + district
return {
  textColor: '',
  separatorColor:'',
  selectionColor: '',
  attributes: {
The Arcade expression in the ArcGIS Dashboards Expression window
  1. Scroll down to the Template editor dialog box and type the attribute expression syntax into the desired position. In this example, the {expression/location} syntax is used.
  2. Click Done.
The List options menu
Shown below is the list element with the Arcade expression.
The List element with the Arcade expression enabled
Article ID: 000030956
Software:
  • ArcGIS Online
  • ArcGIS Dashboards
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
