HOW TO
Apply a line symbol to a polygon outline in ArcGIS Pro
Last Published: May 8, 2025
Summary
It may sometimes be preferable to use line symbols from the ArcGIS Pro gallery to outline polygon feature classes, as shown in the image below:
Procedure
This can be done using the advanced Structure functionality from the Symbology pane.
  1. Ensure that the polygon layer is selected from the Contents pane.
  2. Click the Feature Layer tab and then click the Symbology button to open the Symbology pane, as shown in the next image.
  1. Select the Single symbol primary symbology, click the symbol icon to open its properties, and click the Structure tab.
For this example, the Single Symbol primary symbology was used, but the same steps work with other types of symbology.
  1. Delete the outline symbol from the Layers list, as shown in the next image.
  1. Click the Add symbol layer button and select the Import layers from a symbol option as seen in the next image.
  1. The Import layers from symbol window displays. In the Symbol type drop-down menu, select the Line symbol option and choose the desired line symbol from the gallery.
  2. Click Import to save the changes.
  1. Apply the changes in the Symbology pane. As a result, the polygon outlines have the desired line symbology, as shown in the image below:
Article ID: 000031865
Software:
  • ArcGIS Pro 3 2
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
