HOW TO
Apply a custom sorting to the categories in the Category selector in ArcGIS Dashboards
First Published: March 3, 2021
Last Published: May 10, 2021
Summary
When using the Category selector in a dashboard, Category Field can only be sorted by the selected field or Count. There is no option to sort the selected Category Field by other fields in the layer. This article describes the workflow to apply a custom sorting to the categories in the Category selector in ArcGIS Dashboards.
In this example, there are two fields in the layer table, State and Population. The selected Category Field is State, but there are only two options in the Sort By section, State and Count. It is not possible to sort the State field by the Population field.
The Data tab showing the layer's table consisting the State and Population fields in ArcGIS Online.
The Category Selector in ArcGIS Dashboard displaying the Category Field and Sort By parameters.
Procedure
Complete the steps below to apply a custom sorting in the Category selector in ArcGIS Dashboards:
  1. In ArcGIS Online, click Content > My Content, and select the layer used in ArcGIS Dashboards.
  2. In the layer's item details page, click the Data tab, and add a new integer field to the table using the Table or Fields view. Refer to ArcGIS Online: Add a field for steps to do so. In this example, the new field is Rank.
The Add Field dialog to add a new integer field in the layer from the item details page.
  1. Populate each value in the new field based on the Population field's values. In this example, the Rank field is populated with 1, 2 and 3 according to each value in the Population field in a descending order.
Populating each value in the Rank field based on the Population field's values
  1. Create a list for the Rank field, and manually label its values with the State field's values.
    1. On the Data tab, click Fields. Under Display Name, click the new field. In this example, the field is Rank. The Rank field's page opens.
    2. On the Rank field's page, click Create List.
Clicking Create List in the field page of Rank.
  1. In the List of Values: window, under Label, add the State's names and under Code, add the corresponding Rank field's values.
  2. Click Save.
The List of Values window displaying the added values in the Label and Code sections.
  1. Open ArcGIS Dashboards in edit mode, and customize the Category selector.
    1. In ArcGIS Dashboards, hover on the header or side panel, click the Add Category selector The Add Category selector icon. icon. The Category Selector page opens.
    2. Click the Selector tab, and on the Selector Options pane, in the Categories From section, select Grouped Values. The Select a layer page opens. Under Layers from 'Dashboard_name' map:, click the desired layer.
    3. On the Selector Options pane, in the Category Field section, select Rank from the drop-down list.
    4. In the Sort By section, select Rank from the drop-down list.
    5. Click Done.
The Selector Options pane displaying the Categories From, Category Field and Sort by parameters.
Article ID: 000023729
Software:
  • ArcGIS Online
  • ArcGIS Dashboards
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
