HOW TO
Append tapestry information to address points to determine the percentage of a dominant segment in ArcMap
Summary
In a large tabular dataset of addresses, it is useful to apply tapestry information to address points so the percentage of the dominant tapestry segment can be determined. For example, when integrating consumer traits with residential characteristics to identify markets and classify neighbourhoods. For more information on tapestry segmentation in U.S. residential areas, refer to Esri Demographics: Tapestry Segmentation.
Procedure
This article describes how to apply a tapestry segment (in this example, customers) to address points to determine the percentage of the segment per sub-region (in this example, the sub-region of Worcester) in ArcMap.
  1. In the Business Analyst toolset, use Customer Setup Wizard to geocode addresses in the dataset, and apply a tapestry code to the resulting customer points layer.
This process consumes credits.
  1. On the Business Analyst toolbar, click Business Analyst > Customer Setup. This opens the Customer Setup Wizard window.
  2. Perform Steps 11 through 17, as outlined in ArcMap: Geocoding your stores and customers.
  3. Check the Append segmentation code to address records. option. Click Next.
Image of Customer Setup Wizard window
  1. Name the customer points layer and click Finish. The customer points layer is created. The tapestry code is shown in the attribute table of the customer points layer.
Image of Tapaestry Code column in the Attribute Table
  1. Select and export the customer point features as an Excel file based on the desired sub-region.
    1. Open the attribute table of the customer points layer.
    2. Use the Select By Attribute tool to select customer points from a state, region or sub-region. In this example, customer points are selected from the Worcester sub-region.
Image of Select By Attributes window
  1. Use the Table to Excel tool to export the selected customer point features as an Excel file. Check the option to use field aliases as column headers.
  1. In Microsoft Excel, open the .xls file, and use the COUNTIF function to calculate the percentage of customers in the sub-region.
=COUNTIF(range, criteria)/COUNTA(range)
Image of Percentage calculation of Tapestry Code in Excel
The image shows the percentage of the tapestry code segmentation in the Worcester sub-region.
Image of Percentage of the tapestry code segmentation in Worcester sub-region
Article ID: 000018970
Software:
  • ArcGIS Business Analyst Desktop
  • ArcMap 10 7
  • ArcMap 10 8
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
