HOW TO
In ArcGIS Pro, ArcGIS API for Python can be used to automate the process of updating the field data records in the attribute table of a feature class from a CSV file. Follow the workflow described in this article to update the attribute table from a CSV file and add new rows using a stand-alone Python file (.py). The Python file also runs in Jupyter Notebook.
import arcpy
workspace =r"<GeodatabasePath>" fc = r"<featureClassPath>" csv = r"<csvPath>" copy_fields = ["<fieldName1>", "<fieldName2>", "<fieldName3>"]
edit = arcpy.da.Editor(workspace) edit.startEditing() edit.startOperation()
csv_dict = {row[0]: row for row in arcpy.da.SearchCursor(csv, copy_fields)}
with arcpy.da.UpdateCursor(fc, copy_fields) as cursor:
    for row in cursor:
        key = row[0]
        try:
            new_row = csv_dict[key]
        except KeyError:
            print(f"Entry not found in csv: {copy_fields[0]} = {key}")
            continue
        cursor.updateRow(new_row)
        del csv_dict[key]
with arcpy.da.InsertCursor(fc, copy_fields) as cursor: for new_row in csv_dict.values(): cursor.insertRow(new_row)
print("<message>")
edit.stopOperation()
edit.stopEditing(True)
The code block below demonstrates the full working script.
workspace = r"C:\Users\testUser\Documents\Article work\Article 29321\MyProject 29321\MyProject 29321.gdb"
fc = r"C:\Users\testUser\Documents\Article work\Article 29321\MyProject 29321\MyProject 29321.gdb\Schools_all"
csv = r"C:\Users\testUser\Documents\Article work\Article 29321\schoolLvl.csv"
copy_fields = ["NAME", "LEVEL_NO", "LEVEL"]
import arcpy
edit.startEditing()
    for row in cursor:
        key = row[0]
        try:
        except KeyError:
            continue
        del csv_dict[key]
print("Complete")
                Article ID: 000029321
Get help from ArcGIS experts
Start chatting now
