HOW TO
Append a new row into a feature attribute table from an existing CSV file using Python in ArcGIS Pro
First Published: March 3, 2023
Last Published: May 8, 2025
Summary
In ArcGIS Pro, ArcGIS API for Python can be used to automate the process of updating the field data records in the attribute table of a feature class from a CSV file. Follow the workflow described in this article to update the attribute table from a CSV file and add new rows using a stand-alone Python file (.py). The Python file also runs in Jupyter Notebook.
Procedure
  1. Import the necessary module.
import arcpy
  1. Specify the parameters for the feature class file location, the csv file location, the workspace, and the fields involved.
workspace =r"<GeodatabasePath>"
fc = r"<featureClassPath>"
csv = r"<csvPath>"
copy_fields = ["<fieldName1>", "<fieldName2>", "<fieldName3>"]
  1. Start the edit session.
edit = arcpy.da.Editor(workspace)
edit.startEditing()
edit.startOperation()
  1. Create a dictionary to store the values for the fields.
csv_dict = {row[0]: row for row in arcpy.da.SearchCursor(csv, copy_fields)}
  1. Iterate through the features using the UpdateCursor() function.
with arcpy.da.UpdateCursor(fc, copy_fields) as cursor:
    for row in cursor:
        key = row[0]
        try:
            new_row = csv_dict[key]
        except KeyError:
            print(f"Entry not found in csv: {copy_fields[0]} = {key}")
            continue
        cursor.updateRow(new_row)
        del csv_dict[key]
  1. Apply the InsertCursor() function to insert any new fields in the feature class.
with arcpy.da.InsertCursor(fc, copy_fields) as cursor:
    for new_row in csv_dict.values():
        cursor.insertRow(new_row)
  1. Apply the print() function to show a message when the attribute table is updated and stop the edit session.
print("<message>")
edit.stopOperation()
edit.stopEditing(True)
The code block below demonstrates the full working script.
workspace = r"C:\Users\testUser\Documents\Article work\Article 29321\MyProject 29321\MyProject 29321.gdb"
fc = r"C:\Users\testUser\Documents\Article work\Article 29321\MyProject 29321\MyProject 29321.gdb\Schools_all"
csv = r"C:\Users\testUser\Documents\Article work\Article 29321\schoolLvl.csv"
copy_fields = ["NAME", "LEVEL_NO", "LEVEL"]
import arcpy
edit.startEditing()
    for row in cursor:
        key = row[0]
        try:
        except KeyError:
            continue
        del csv_dict[key]
print("Complete")
Article ID: 000029321
Software:
  • ArcGIS Pro
  • ArcGIS API for Python
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
