HOW TO
Alter field aliases using Python in ArcGIS Pro
First Published: February 8, 2023
Last Published: April 7, 2023
Summary
In ArcGIS Pro, the Fields toolset contains tools to create and modify fields for any geodatabase table or feature class. These modifications can be made by running a Python script in ArcGIS Pro and this article provides the workflow.
The image below shows the Schools_all attribute table with field aliases containing underscores and lower case letters.
The Schools_all attribute table
Procedure
  1. Start ArcGIS Pro and open the project.
  2. To open the Python window, on the top ribbon, click Analysis, click the Python drop-down list arrow and select Python Window.
The Python window icon in the Python drop-down box on the Analysis tab
  1. Specify the following script in the Python window.
    1. Import the system modules.
import arcgis
import os
  1. Specify the ArcPy function to check extensions and overwrite outputs.
arcpy.env.overwriteOutput = True
  1. Specify a variable Syntax to list all the field names of the layer.
<variableName> = arcpy.ListFields('<layerName>')
  1. Specify the ArcPy function to apply the changes to the field alias. In this example, the initial letter is capitalized and '_' is replaced with a space.
print("Changing the field alias to field name by Capitalizing the initial letter")
for field in <variableName>:
    if not field.required:
        arcpy.management.AlterField('<layerName>', field.name, field.name, field.name.rstrip(field.name[-2:]))
        arcpy.management.AlterField('<layerName>', field.name, field.name, field.name.replace("_"," ").title())
        print("Completed")
The following code block demonstrates the full working script.
import arcpy
import os
arcpy.env.overwriteOutput=True
infeature=arcpy.GetParameterAsText(0)
fields=arcpy.ListFields('Schools_all')
for field in fields:
        arcpy.management.AlterField('Schools_all', field.name, field.name,field.name.rstrip(field.name[-2:]))
        arcpy.management.AlterField('Schools_all', field.name, field.name, field.name.replace("_"," ").title())
        print("Completed")
The image below shows the updated field aliases using Python in ArcGIS Pro.
Part of the Python script and results of the updated field aliases
Article ID: 000029252
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
