HOW TO
This document describes how to allow an .apr to be opened by only one user at a time via Avenue.
Code:
'Startup Script --------------------------------------
ps = av.getproject.getfilename.clone
psd = ps.stripfile
'MsgBox.Info(ps.AsString,"")
ptitleapr = av.GetProject.GetWin.GetTitle.Clone
ptitle = ptitleapr.AsString.Substitute(".apr","apr")
text_file = "\"+ptitle+".txt"
thefilestr = psd.AsString+text_file.AsString
_textfilename = thefilestr.AsString.AsFileName
checkfile = FileName.FindInSystemSearchPath (_textfilename.AsString)
if (checkfile <> nil) then
theLineFile = linefile.make(_textfilename,#FILE_PERM_READ)
thelist = List.Make
numlines = theLineFile.GetSize
source = theLineFile.Read( theList,numlines )
a = theList.count
pos = theLineFile.SetPos (0)
info_list = list.make
for each l in theList
theline = theLineFile.ReadElt
info_list.Add(theline)
end
MsgBox.Warning(info_list.Get(0).AsString++
"is currently using this project on"++info_list.Get(1).AsString+NL+
"Login date and time:"++info_list.Get(2).AsString+NL+
"Check with the above user. Closing the project","W A R N I N G !!")
av.run("Project.Close",nil)
else
' DETERMINE IS OPERATING SYSTEM IS WINDOW BASED
' SET %SystemRoot% IF WINDOWS NT OR 95
OSvar = System.GetOSVariant
if (OSvar = #SYSTEM_OSVARIANT_MSWNT) then
wd = system.GetEnvVar("windir")
_WinSysDir = wd+"\system32\"
elseif (OSvar = #SYSTEM_OSVARIANT_MSW95) then
else
MsgBox.Warning("This project is designed for use" +NL+
"by WindowsNT and Windows95 PCs.","Stop")
av.GetProject.Close
end
' DETERMINE THE USER LOGIN NAME
'Make the DLL object
dllAdvAPI32 = dll.make((_WinSysDir + "advapi32.dll").AsFileName)
'Make the DLLProc object
dpGetUserNameA = dllproc.make(dllAdvAPI32, "GetUserNameA",
#DLLPROC_TYPE_INT32,{#DLLPROC_TYPE_STR, #DLLPROC_TYPE_PINT32})
'Make the string buffer
uname = String.MakeBuffer(12)
buflen = 10
retValue = Number.MakeNull
'Call the function which returns the username to the buffer
retValue = dpGetUserNameA.Call({uname, buflen})
tf = LineFile.Make(_textfilename, #FILE_PERM_APPEND)
mystr = Uname.AsString
'MsgBox.Info(mystr.AsString,"")
tf.WriteElt(mystr)
' DETERMINE THE COMPUTER NAME
dllKernel32 = dll.make((_WinSysDir + "kernel32.dll").AsFileName)
dpGetComputerNameA = dllproc.make(dllkernel32, "GetComputerNameA",
cname = String.MakeBuffer(12)
buflen = 10
retValue = dpGetComputerNameA.Call({cname, buflen})
compname = cname.AsString
'MsgBox.Info(compname,"")
tf.WriteElt(compname)
d = Date.Now.AsString
tf.WriteElt(d)
tf.close
end
'END OF STARTUP SCRIPT -------------------
Code:
'ShutDown Script -------------------------------------
else
av.GetProject.Close
end
buflen = 10
buflen = 10
checkfile2 = FileName.FindInSystemSearchPath (_textfilename.AsString)
if (checkfile2 <> nil) then
theLineFile2 = linefile.make(_textfilename,#FILE_PERM_READ)
thelist = List.Make
numlines = theLineFile2.GetSize
source = theLineFile2.Read( theList,numlines )
a = theList.count
pos = theLineFile2.SetPos (0)
theline = theLineFile2.ReadElt
end
end
if (info_list.Count > 0) then
user = info_list.Get(0).AsString
comp = info_list.Get(1).AsString
else
return nil
end
if ((mystr = user) and (compname = comp)) then
_theLineFile = nil
_tf = nil
theLineFile2 = nil
av.PurgeObjects
File.Delete(_textFileName)
else
end
'END OF SHUTDOWN SCRIPT ------------------
Warning:
Users should never open two versions of the application, with the same project file on their local machine. This could allow for corruption of the project file.
Article ID:000005200
Get help from ArcGIS experts
Download the Esri Support App
