HOW TO
An Enhanced Compressed Wavelet or ECW file can be added to a mosaic dataset in ArcGIS Pro. While this is a supported raster format, it is also a non-Esri proprietary format and sometimes the performance is sub-optimal.
A common workflow to add data to a mosaic dataset is to create an empty mosaic and use the Add Rasters to Mosaic Dataset tool with Update Overviews checked. Overviews are lower-resolution images created to reduce CPU usage and increase display speed. See: Mosaic dataset overviews. However, sometimes when the Overviews option is checked in the geoprocessing parameters, the resulting mosaic can appear darker or lighter than the original imagery, as shown in the following image.
To resolve this problem:
The data in the mosaic dataset should now appear the same as the original, as shown in the image below.
Article ID: 000033920
Get help from ArcGIS experts
Start chatting now
