HOW TO
Add points using keyboard shortcuts with Measurement in ArcGIS Experience Builder
Last Published: January 21, 2025
Summary
In ArcGIS Experience Builder, adding points using keyboard shortcuts with the Measurement widget streamlines the process of spatial data collection and enhances user efficiency. This feature enables precise point placement, even in complex map areas, and facilitates measuring distances or areas between locations. This article describes the workflow to add points using keyboard shortcuts with the Measurement widget in ArcGIS Experience Builder.
Procedure
  1. Open the web experience in ArcGIS Experience Builder.
  2. In the Insert widget panel, under the Map centric group, drag and drop the Measurement widget onto the canvas.
  3. On the Measurement widget, select a measurement tool. In this example, Distance Distance icon is selected.
  4. On the map, press F on the keyboard to add a point to the map. Repeat this step to add subsequent points.
Map with points added using the keyboard shortcut
To delete the previous point on the map, press Z on the keyboard.
  1. On the keyboard, press Enter to end the measurement. Alternatively, double-click to end the measurement.
This workflow is applicable to both Distance Distance icon and Area Area icon measurement tools in the Measurement widget.
The web experience below shows the distance between the points created using the keyboard shortcut displayed in the widget.
Map with the measurement displayed in the Measurement widget
Article ID: 000034394
Software:
  • ArcGIS Online
  • ArcGIS Experience Builder
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
