HOW TO
Add placeholder text for text questions in ArcGIS Survey123 Connect
First Published: November 2, 2023
Last Published: November 22, 2024
Summary
In ArcGIS Survey123 Connect, formulas can be applied to survey questions to modify the way a question is displayed. For example, customizing a survey question to show hints as a placeholder text within the question text box.
This article provides the steps to add a placeholder text within the question text box in ArcGIS Survey123 Connect.
An example of the ArcGIS Survey123 Connect survey form
Procedure
  1. In ArcGIS Survey123 Connect, open the survey's XLSForm.
  2. Create a text question in the survey worksheet. In this example, the text question type is created.
    1. Specify a name for the question that is not listed in the Reserved worksheet, and under the label column, specify the name of the question and the text to be displayed for the question as the label in the form. In this example, the question is named 'candidateQual' and 'Academic Qualification(s)' is the label.
    2. Under the hint column, specify the actual text to be displayed in the text box for the question in the form.
    3. Under the body::esri:style column, specify the following formula.
placeholderText=@[hint]
The edited XLSForm
  1. Click Save The Save icon.
The image below shows the placeholder text within the question text box.
The ArcGIS Survey123 Connect survey
Article ID: 000031399
Software:
  • ArcGIS Survey123 Connect
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
