HOW TO
Add or change ArcGIS functionality without editing the registry
Summary
You should not directly edit your Windows registry as doing so would pose a high risk on the integrity of your machine. You can modify many of ArcGIS options from the user interfaces for ArcMap, ArcCatalog, ArcToolbox and ArcScene. The few options not available from the interface can be modified by using the ArcMap Advanced Settings utility.
Procedure
Use ArcMap Advanced Settings utility to make modifications to ArcMap options that may or may not be available in the user interface.
A. Navigate to the Utilities folder under the ArcGIS installation directory; for example, C:\arcgis\arcexe81\Utilities.
B. Double-click AdvancedArcMapSettings.exe.
Article ID:000003930
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
