HOW TO
When adding a stand-alone table or dataset formatted with leading zeroes in the numeric field to ArcGIS Pro, the zeroes are omitted from the attribute table by default. The leading zeroes can be re-added to the field by configuring the number format in the attribute table settings. This article provides the workflow to insert the leading zeroes in numeric field values in ArcGIS Pro.
The image below shows the NumberTestLong field without any leading zeroes in ArcGIS Pro. In this example, the leading zeroes are added to the NumberTestLong field.
to open the Number Format dialog box.
The image below shows the leading zeroes are added in the NumberTestLong field when viewed in the attribute table.
Article ID: 000031181
Get help from ArcGIS experts
Start chatting now
