HOW TO
Add leader lines to labels in ArcGIS Pro
First Published: October 25, 2023
Last Published: July 22, 2024
Summary
In ArcGIS Pro, leader lines can be added to labels in a feature class. This is useful for linking labels to corresponding points on the map for more clarity. This article provides the workflow to add leader lines to labels in ArcGIS Pro using a background callout with an arrow leader line. The image below shows a point feature class with labels enabled on the map.
A point feature class with labels on a map
Procedure
  1. Open the ArcGIS Pro project.
  2. In the Contents pane, right-click the feature class and click Labeling Properties to open the Label Class pane.
  3. In the Label Class pane, on the Symbol tab, expand Callout and select Background.
Adding a background callout to the feature class labels
  1. Add a leader line with an arrow to the background callout.
    1. For Background symbol, select a polygon symbol.
    2. For Leader line symbol, click the drop-down arrow > More line symbols… to open the Choose a line symbol window.
    3. In the Choose a line symbol window, search for ‘Arrow’ in the search box, select the desired arrow line, and click OK. In this example, Arrow Line 2 is selected.
Selecting a leader line with an arrow in the Choose a line symbol window
  1. Configure the placement of the leader line arrow.
    1. In the Label Class pane, click the Leader line symbol drop-down arrow > Format line symbol.
    2. In the Format Embedded Line Symbol subpane, click the Layers The Layers icon icon.
    3. Expand Marker Placement, click the Extremities drop-down arrow, and select At begin. This places the arrow at the other end of the leader line.
Configuring the arrow to be placed at the beginning of the leader line
  1. Configure the style of the leader line.
    1. In the Label Class pane, click the Return to previous symbology page The Return to previous symbology page icon icon.
    2. Under Callout, select a style for Leader style. In this example, Three point is selected.
    3. Configure any remaining text symbol properties of the background callout as desired, and click Apply.
Configuring the style of the leader line and applying the changes
The image below shows the feature class labels with a leader line pointing to the point symbols.
The labels  with a leader line pointing to the corresponding points on the map
Article ID: 000031347
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
