Summary
The ICoverageAnnotationLayer interface can be associated with an IFeatureLayer that is set using the ClassByName property of an IFeatureClassContainer.
Procedure
- Use a WorkspaceFactory object to create a pointer to the location of the data. Each data model requires its own type of WorkspaceFactory object. Consult the Geodatabase object model diagram for the various types.
'++ Create a pointer to the data's workspace:
Dim pWorkspaceFact As IWorkspaceFactory
Set pWorkspaceFact = New ArcInfoWorkspaceFactory
Dim pWorkspace As IWorkspace
Set pWorkspace = pWorkspaceFact.OpenFromFile("c:\geodata\covers", 0)
Dim pFeatureWorkspace As IFeatureWorkspace
Set pFeatureWorkspace = pWorkspace
- Open the dataset by pointing a FeatureDataset object at the workspace's OpenFeatureDataset method.
Dim pDataset As IFeatureDataset
Set pDataset = pFeatureWorkspace.OpenFeatureDataset("covername")
- Create a pointer to the desired annotation feature class of the dataset using an IFeatureClassContainer with the ClassByName property.
Dim pFeatureClassContainer As IFeatureClassContainer
Set pFeatureClassContainer = pFeatureDataset
Dim pFeatureClass As IFeatureClass
Set pFeatureClass = pFeatureClassContainer.ClassByName ("annotation.subclass")
- Create a new instance of an ICoverageAnnotationLayer object and associate it with an IFeatureLayer object.
Dim pCoverageAnnotationLayer As ICoverageAnnotationLayer
Set pCoverageAnnotationLayer = New CoverageAnnotationLayer
Dim pFeatureLayer As IFeatureLayer
Set pFeatureLayer = pCoverageAnnotationLayer
- Set the IFeatureLayer object's FeatureClass method to the annotation subclass referenced by ClassByName property above.
Set pFeatureLayer.FeatureClass = pFeatureClass
pFeatureLayer.Name = "Feature class name"
pFeatureLayer.Visible = True
- Add the layer to ArcMap with the IMap:AddLayer method.
Dim pMxDocument As IMxDocument
Set pMxDocument = ThisDocument
pMxDocument.FocusMap.AddLayer pFeatureLayer
